UNIMOG 1300L / 435 -- Sourcing vehicle & parts
#1 Beitrag von Gast » Sa 31 Aug 2002 13:25
Hi everyone,
My apologies if I don´t write german on this board..but there are no other equivalent elsewhere on the web (idem for bushtaxi.de)
I am looking at purchasing a U1300L/435 from the BW to import it into Switzerland. This is to be transformed into a expedition vehicle to go with my HZJ78.
Would someone be kind enough to recommend some sources where I could purchase such vehicle. I am not planning to buy direct from the BW but go through individuals or dealers.
1) I know inter-commerz and Aigner. What do you think of them ?? Other dealers you could recommend ?
2) Also what´s the going rate for purchasing a U1300L. I have been quoted all sorts of prices (15-25 KEuros)
3) Things to look for when buying the truck - I don´t know how well these trucks were looked after in the BW. Low mileage is not a good indicator
4) Mechanical transformations so of you may have done (longer axle ratio....)
thanks,
sierra
Re: UNIMOG 1300L / 435 -- Sourcing vehicle & parts
#2 Beitrag von Gast » Sa 31 Aug 2002 14:06
Hi Sierra Nevada,
look at www.unimogs.de (MEREX GMBH, Gaganau): They are good but there are not the cheapest.
Direct Source BW: www.vebeg.de (allso in english): BUT TAKE CARE!!! IST NOT SO EASY!
Thanks for UNIMOG 1300L / 435 -- Sourcing vehicle & parts
#5 Beitrag von Gast » So 01 Sep 2002 11:52
Thank you guys. I will check out these sites.
