Hello friends from Spain
  • Uro-Camper
  • 18. August 2011 um 16:23
  • Uro-Camper
    Spain
    Sorry for my bad writing. I use google translator.
    I'm staying here with you to learn more.
    I made our first cell and now we will start the second cell. We set up a company dedicated to this but we need to acquire more knowledge. I would like to know your opinion. We are in Spain.
    Photographs of the construction process.
    Thanks!!!!
  • Uro-Camper
    Spain
    • 18. August 2011 um 22:59
    http://img830.imageshack.us/img830/5237/imageiif.jpg
  • bernhard_h
    • 19. August 2011 um 07:49
    Hola Uro-Camper (?)
    nice piece of work and nice documentation. maybe helpfull for people with similar projects, thanks for sharing this with us.
    unfortunately my spanish is years old and non existant anymore
    buena fin de semana adios, bernhard
    • 19. August 2011 um 19:23
    looks like an interisting construcktion. I have never seen before that sandwich plates were connected with wooden corners.
    How will this be sealed so that there is no water intrusion?
  • Uro-Camper
    Spain
    • 19. August 2011 um 23:53
    Thanks for the comments!!!
    The following photographs you will understand be ausencia water can never enter to inside.
  • Uro-Camper
    Spain
    • 19. August 2011 um 23:56
  • Uro-Camper
    Spain
    • 21. August 2011 um 23:40
    When the structure and the walls is finished I give polyester putty to imperfections. Then paint with primer.
    2 Mal editiert, zuletzt von Uro-Camper (21. August 2011 um 23:49)
    • 22. August 2011 um 09:34
    Hello, Uro-Camper,
    I am not quite sure about your wall-construction. Are those made of wood-polystyrol-wood or of glass-fiber reinforced plastic - polystyrol - glass-fiber reinforced plastic? In both cases: is it correct that you only use primer and paint to seal the frame against the wall-plates? If so I am afraid of problems in the future of the cabins: any damage (by branches of trees or distortion while driving in terrain) will cause intrusion of water into the walls or the frame and your cabin will rot away from the interior...
    Most professional cabin-manufacturers do not use wood inside the cabin-structure anymore because of the danger, intruding water means to the life-cycle of the cabin... If wood in the walls, then keep the outer layer as waterproof as possible (primer and paint is not enough for this job) and the inner layer should be as permeable and capable of diffusion to allow intruding water to dry up as fast as possible.
    Best luck for your project
  • Uro-Camper
    Spain
    • 22. August 2011 um 18:52
    Hello.
    Water does not enter into the walls ever. This is impossible.
    After applying the primer applied a plastic spray. It is a polymer that wraps around the cabin. It is a shock resistant plastic. Waterproof.
    In the following video you can see an egg wrapped in this plastic
    You see there is no wood. No joints. Only plastic.
    Now we start with the furniture ..........
  • Uro-Camper
    Spain
    • 25. August 2011 um 10:03
    more pics..........
    • 25. August 2011 um 13:20
    Hello Uro-Camper, aka Tribu, ;)
    this is a very interesting project.
    But don't let us wait that long for your final pictures. :wink:
    The final version of the white colored cabin and to cover the interior with the polyurea looks good.
    (I've seen the other pics already). 8)
    I think it is a good idea to protect the cabin with that stuff. I've something similiar on my truckbed.
    How is the thickness wich is sprayed on the surface of the cabin and the furniture? My question is because of the added weight.
    It is a pity that you're that far away from me. Over 2TKm is a bit to far to have a preview of your project.
    Will you produce cabins like that as a company?
    Or is it only to show the possibilities of your normal business?
    You should also show your project on Germanys biggest platform for Truck-Campers:
    http://www.wohnkabinen-magazin.de/
    Their are certainly a lot of people interested on your cabin.
    Btw:
    Das besprühen mit so einer Polyurea-Beschichtung ähnlich wie Rhino oder Nasornhaut,
    ist sicher auch ne gute Alternative für die immer mal gern genommenen Siebdruckplatten für den Kabinen oder Anhängerbau.
    Damit erledigt sich auch das "Dichtigkeits-Problem". :wink:
    Einmal editiert, zuletzt von Questman (25. August 2011 um 15:40)
  • jfk
    • 25. August 2011 um 13:51
    nur wo bekomm ich das Zeug her?
    (Answer for that german Part above: Where do i get this stuff?)
    • 25. August 2011 um 15:01
    ... z.B. von Golieth Trans-Lining - ich glaube, Tobi hat sich von denen die PUR-Beschichtung in die Naßzelle sprühen lassen, ich selbst habe mir dort die streichbare Version zur zusätzlichen Abdichtung (und UV-sicheren Abdeckung) meiner GfK-Profile gekauft.
    • 25. August 2011 um 16:07
    Gibts hier und dort unzählige Threads. ;)
    Suchbegrife:
    Ladeflächenbeschichtung
    Polyurea
    Polyuretan
    PU-Beschichtung
    Mit PU-Beschichtung meine ich Polyurethan-Beschichtung ala "Rhino-Linings", "Nashornhaut", "Trans Lining",
    oder auch das Zeug was "MaTTec" als Protecta-Kote oder
    Hercules zum Selbstaufpinseln vertreibt um nur einige Beispiele zu nennen.
    Nur selber machen hat nicht die selbe Qualität, wie naß in naß gespritzt.
    Aber frag mal Michael und Cordula.
    Die können solch einen Polyurethanlack besorgen der ähnliche Eigenschaften hat
  • Uro-Camper
    Spain
    • 29. August 2011 um 21:39
    Questman Hello!
    I will put all the pictures already.
    The applied thickness is 2 mm. The weight of the Uro-Camper Kubic 1.0 is 360 kg with furniture included.
    You can apply least 2 mm thick but offers much resistance.
    I would like you to have the honor to submit to us in the forum http://www.wohnkabinen-magazin.de/
    If all goes well we want to open a manufacturing company.
    Thanks.
  • Uro-Camper
    Spain
    • 29. August 2011 um 21:53
    My camper....... :lol::lol:
    • 30. August 2011 um 12:11
    Hello "Uro-Camper" ???,
    hear you can see the thread:
    http://www.wohnkabinen-magazin.de/de/forum/31-so…ain.html#107428
    You should register yourself to anwser questions.
    Good luck for your business-plans for building a company.
    One of the most common questions will be a price for your cabins.
    Do you plan to ad jack supports for the cabin?
    • 30. August 2011 um 14:12
    Hi Uro-camper,
    Zitat von Uro-Camper
    ...The weight of the Uro-Camper Kubic 1.0 is 360 kg with furniture included. ...
    your cabin looks quite pretty! But such a small cabin and 360kg? That's quite a lot! I'm in contact with other manufacturers about my new dismountable cabin (bottom length 2.8m, height 2.3m, width 2.1m with an alcoven of 2m length and 1m heights) and we are talking about 300 to 350kg (without furniture) for this much larger cabin...
    But nevertheless: I wish you all the best for your plans...
  • Rudi
    • 30. August 2011 um 19:41
    Hallo Uro-Camper
    Wie stark ist das Sandwich
    Welches Material hat das Sandwich , Holz oder GfK ??
    Translate Google
    How strong is the sandwich
    Which has the sandwich material, wood and fiberglass?
    Qué tan fuerte es el sandwich
    Que tiene el material del emparedado, madera y fibra de vidrio?
    Gruß Rudi
  • Uro-Camper
    Spain
    • 30. August 2011 um 22:40
    Zitat von Rudi
    Hallo Uro-Camper
    Translate Google
    Strong:
    Sandwich: pvc + Foam + pvc
